Old 01-28-2002, 02:46 PM
MDR MDR is offline
Default Problem solved
I played with the car a bit today.Here is what I did to fix the problem I was having, I removed the vac. advance and after some careful marking and guessing I drilled a hole for a very small self taping screw in the arm that comes off the vac. adv. after cutting the threads in to the arm I had to remove the screw and grind it down since the length would pose a problem. Now when the vac. adv. kicks in there is about 1/2 the range of motion then the head of the screw acts as a stop against the dist. housing.I fired her up and took it up to 3500 and above with no miss, I'm a happy camper, hope this can help someone else.
Mike
