Old 03-27-2011, 04:23 PM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Not sure I can identify what it is as of yet. Perhaps others can...
Do you have a seperate trunk & hood lid skins? These pieces will be needed when the cut-outs are made. Also the underside of both these components have additional fiberglass structure that is not shown and will be needed.
Have the trunk & engine bay inner-skin/structure been glassed in? What about all the steel structure that would be in front of the dash that makes up the door hinge mounting points and chassis bolting mounts.? Also steel hoop in the trunk that will be the rear mounting points to the frame and roll bar mount.
Cockpit does look similar but the dash does not look like a Butler at all. Not mine at least.
Do you have door inner & outer panels with the hinge/catch beam structures?
Looking forward to seeing the frame photos.
Arthur
