Old 03-29-2011, 10:01 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
Default sbf oil inlet fitting size
is there a fitting that will screw onto the 3/4-16 and go to an12 flare or an10 flare size?
or can the std ford 3/4-16 oil inlet fitting be removed and another fitting be inserted to go to the an12 or an10 flare?
what is the thread size or how is the oil filter adapter fitted into the block?
would like to remove the block of aluminum adapter using now and go straight into the oil inlet port.
