Old 04-01-2011, 12:53 PM
Learjockey1 Learjockey1 is offline
Cobra Make, Engine: ERA #539/427 Holman Moody #7HM20 from 1967
Undy it looks like you pulled your upper fuel vent extentions out. Any problems??
The top of my oval air filter top comes awful close and with my last set of carbs, it was sitting on the air horns. My filter base is flat aluminum plate with holes cut out for the adjusting screws and other carb upper protrusions and then I used cut off spoons bottoms to cover the holes etc.
The choke horns were milled off these. When the carbs were built I asked that the vent tubes be cut minimim height but it seems they are the stock height. Does anyone know what is a good minimin height and issues involved with shorter ones??
