Greg,
Unless Classic went out of buiz in the last few days, they are still around. I think Classic puts out a quality product. It uses the mustang II front suspention config and the 8.8 rear out of the 79&up Mustang. As far as I know, the fiberglass is very good.(having dealt with a finished body and having talked with DV about it) The frame is really stout. The main rails are the rectangular type that are formed by a machine that bends them (Less welded seams that could fail), (I sure would like to see the machine that does that) The frame really has a production Quality to it not found on other cars. The body can be removed from the frame later on after the car is done if need be. (some can't) The wireing harness I have seen and delt with is of high quality. The kit should come with an assembly manual. The ones I have seen have a lot of pictures and information. As petec has stated, you really want to talk to DV. He has built many of these cars and knows them inside and out.
Good luck! let us know what you do!,
Steven R
PS, where abouts in Texas is Colleyville ?
