Old 04-03-2011, 05:51 AM
dlampe's Avatar
dlampe dlampe is offline
I worked on it all day yesterday. I didn't shorten anything or add washers but it seems to be running pretty good. I am at least close enough to use the LM1 a/f meter for the fine tuning. I ended up with a similar tune to many other here on the forum.
idle jet 65
idle holder 80
main 160
air corrector 150
f7 tubes (f16's just wouldn't work)
40 exhaust but ordered a 55
40 chokes
mixture screw 3/4 out
There is a point somewhere between 2000 and 3000 when the tone changes but that is OK for now. There is no popping in the pipes or "sneezing" through the carbs. It really doesn't have a stumble anymore, just a point in there where you can feel it not giving you 100%.
The casings are definitely different but they all vary a little. The Italians are not exactly the same and the Spanish are both just a little different too. I bet if all of us blue printed our Weber's we might find that there might be a large acceptable margin of error.
High Maintenance Racing Team
Run & Gun 2003 - 2013
