Old 04-03-2011, 11:29 PM
WardL's Avatar
WardL WardL is offline
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
The tires are Michelin 335/35ZR17. Opps! Sorry, they are only 10.5 " wide. I think I got the HP right....
If you are driving to the limits you are off the gas before you get into a 90 Deg corner. Maybe a set of wide S curves getting tighter. Maybe you are down shifting and doing your heel-toe foot work. I can see screwing up the down-shift going into the corner and causing your rear to come around. Maybe we aren't talking a tight turn but a situation where you are taking a high speed turn and you down-shift instead of braking. There was a You-Tube video where the Cobra rolled after a very slight left at high speed and the rear end went around. Was that an example of TTO? Good night for now!
