Old 04-04-2011, 02:39 PM
Joe Wicked's Avatar
Joe Wicked Joe Wicked is offline
I had a similar problem with an old Trans AM I had years ago. Turned out to be a clogged fuel filter, but even after changing it, it helped but didn't go away completely. Turns out that the pump was having to work a lot harder to get past the clogged filter and it was beginning to fail. It would only happen when it was over 80° outside. If the other ideas don't work, it at least gives you something else to check.
Why do they call it "Common Sense" when it is so rare?
