Thread: Chrome strip...
Old 04-06-2011, 03:13 PM
Trevor W Trevor W is offline
Cobra Make, Engine: Harrison #102 Ford 5l Fuel Injected AU 2
Toecutter
The harrison sills have 3/16" pop rivet heads which I didn't like so I have just fitted 2 Mirror Finish S/S angles 35 X 15X 1450 long fixing from below with 1/8" s/s pop rivets with hind sight I would make the sill face dimension closer to 40m/m and the return 12 if your folder can grip down to that size. Iam fitting non active side pipes Polished S/S so the two together balance I think. Make sure if you use S/S trim you use S/S rivets S/S cuts ally rivets like cheese.
Trevor W
