Old 04-06-2011, 03:14 PM
dcdoug's Avatar
dcdoug dcdoug is offline
That filter as the guys point out is the hard part with the 3/8" lines for the HiPo engines. They are typically $400ish by themselves. Dearborn Tube (Tim Mason) has some nice filters that are similar in appearance and work on the factory bracket. Tim also has the tubes and fittings but I have made those. If you are running a fuel pressure guage you will also need a fuel log with the additional fitting on the back. I have also made those.
+1 for Tim. I got everything I need from him. He has the NOS brackets, etc. The lines are high quality repros, the canister is also a high quality repro, but won't leak like the originals often did. Better than what you'll probably find on Ebay. Tim is generally a very knowledgeable great guy.
www.partskeeper.com
