Old 04-07-2011, 12:37 AM
COBRANIP COBRANIP is offline
Cobra Make, Engine: VSE alum. frame, FFR carbonfiber body (under construction)
What if you replaced the (rear) shocks and springs with a solid piece of bar stock (drilled for mounting) at a length that would hold the hubs at what ever elevation you wanted (i.e. no droop)? I would also remove the (rear) tires and wheels to reduce rotating mass.
