Old 04-07-2011, 02:18 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Dean,
You may find a custom pump rod length is needed.
If the stroke is already used up early then no amount of changing pump bleeds will give the added pump shot you need at that point.
You have the richest e-tube for low end already, maybe choke is too large for the engine?
Or run the 65 with a larger idle air jet.
Gary
