Old 04-08-2011, 06:28 PM
mjhcobra's Avatar
mjhcobra mjhcobra is offline
Cobra Make, Engine: Everett Morrison, 428
May have figured out one possibility for severe angle. It looks like I may have a shock that is too tall. According to the EM catalog, I should use Aldan 658's, with 200 lb springs. This shock has a range of 11.5" to 16.5" with a 12" spring rated at 200 lbs. Looking at the rear of the car, I think there is at least 3" from the top of the tire to the fender well and I do not have any room to adjust the shock.
If this is the issue, the shock may be to long. By using a shorter shock, the rear end will rise within the frame and the angle will lessen.
I suppose there may be a problem with the EM manual for the shock selection or the spring. A 10" spring might be the answer, which would provide adjustment or a shorter shock. Any ideas???
