Old 04-09-2011, 11:41 AM
mjhcobra's Avatar
mjhcobra mjhcobra is offline
Cobra Make, Engine: Everett Morrison, 428
Each of the 4 tires (on stock steel 15" rims with a 26.5" tire, probably 20 years old just to roll around the garage) are blocked up about 4" or so to allow me to slide under the car to check angles.
I am going to now block the frame, support the rear axle, and remove both rear shocks. Hopefully, I can raise the rear axle to get the rear ride height, which should reduce the drive shaft angle and close the gap on the tires in the rear wheel well.
Looks like EM may have made a mistake on the rear shock length. Thanks for the comments, they were all helpful.
