Thread: 392 to ????
Old 04-09-2011, 04:09 PM
blykins blykins is offline
An engine of that caliber shouldn't need head studs, bolts will provide enough clamping force.
Also keep in mind that if you switch to studs, it could cause a different area of cylinder wear if the block was honed with a torque plate and regular bolts (or without a torque plate at all.)
I would make sure that the head bolts have not backed off, then do a leakdown test as Vector said.
Intake gaskets can really screw things up too....especially if something like a Felpro Printoseal intake gasket was used.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
