  #77 (permalink)
Old 04-12-2011, 09:53 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
There's only a couple that I keep around and not in the attic, but the favorite ones I have is record low et from Bakersfield March meet in 70 and 71---
I have several from ISCA in garage attic .
The thing that has been ignored here is the level of shows--they range from the drive/cruize ins at a resturant on a weekly basis----this is a good opt to get your car out and drive it, meet and talk with friends---if you want to enter the competition then your car should be clean or very unique.
Next up would be the monthly type crz of same nature and maybe a little higher level with more cars from a larger geographic area.
Next along that trend are the annual community events generally put on by American Legion, Amvets, Lions Club and these definitely should be spruced up if you enter the comp and are looking for a trophy
Now---when it comes to the off season ISCA type shows (generally winter) you will be damn lucky to even get an entry and if you do----you not only better have your entry clean, polished everywhere, a good display, sign, build picture book, but lighting and music----every screw should be turned so the phillips crosses line up, evenly spaced, and all of the same spec. Everything either counts FOR you or AGAINST you---you need to know the rules before you go so you don't lose the class win just because you didn't have all the tires letters and valve stems lined up-----
