Old 04-15-2011, 08:18 PM
fasterpatrick's Avatar
fasterpatrick fasterpatrick is offline
Cobra Make, Engine: scratch build self design 4.6l DOHC
fasterpatrick Pat what are you going to do with the car???
I know this is a question asked over and over again. I don't mind answering
Auto cross:Maybe
Road racing:No
Drag racing:No
Cruiser and car shows:Spirited driving and runs, local show stuff nothing major.
Does the car have front and rear sway bars??
Yes 1" front / 3/4" rear
What size tires and rims are you running??
245-40 on 17 X 8.5 front; 275-45 on 17 X 10.5 rear.
Was the weight done with 1/2 tank of fuel, all the fluids full, and you in the drivers seat?
No quarter tank of fuel, and my 200lb butt was not in the car.
What size diameter are the sway bars and what ends are on them??
Part A, refer to question 2; Part B, Rod end links.
What shocks do you have??
QA1 PromaStars bearing ends (not poly bushings).
What kind of ride are you looking for??
Firm but not a buckboard, ridden in the latter no like at all.
There is a trade off of handling for soft riding car. Just the different between 15" tires and wheels and 17" tire and wheels is a huge driving differents.
The biggest thing I have seen in the last couple of years is bigger sway bars and lighter spring loads. This gets the car to feel the road better. The jury is still out. If you are looking for handling also check the bumpsteering. Most cars are out on this adjustment alone. Rick L.
Yes I know that, I put a lot of time into getting the geometry to work right I just need to get the car to settle into the sweet spot. I have done a fair bit of research into shock characteristics and would like to use longer stroke and the softer spring approach and add the bump-stops to the shocks to prevent bottoming.
http://www.clubcobra.com/photopost/s...0&ppuser=23754
Well, it occurs to me that perhaps not all of the modifications I made are technically 'street legal'
Nothing good ever happened after this statement;
Hey Moe watch this!
