Thread: Engine builders
Old 04-17-2011, 07:39 PM
BOBBYCOBRA62 BOBBYCOBRA62 is offline
Cobra Make, Engine: SUPERFORMANCE,427 SMALL BLOCK WINDSOR STROKER MOTOR
Default Engine builders
Hey barry,i just found out about you through the web & a call i got from one of the other members.i visited your site,(looks impressive).i own a superformance mk iii cobra replica, which currently has a 427 small-block,(351 windsor-stroker motor) in it. I'm looking to eventually,(as soon as i can afford it),swap out the small-block for an aluminum fe big-block.i have some questions for you regarding blocks,(i.e.-shelby vs.pond vs.genesis),heads,(edelbrock vs.blue thunder) and other stuff: I.e.-cranks,cams,rods,pistons,intakes,carbs,etc.i got your input about the block,(shelby vs.pond).i will be giving you a call to talk to you about that,the other parts and the build.thanks.talk to you soon-bobby!
