Old 04-18-2011, 04:08 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Using VE gear could be difficult.
The ABS (or EBCM - Electronic Brake Control Module) is in the middle of the GMHSLAN, GM High Speed Bus.
You'll need the VE PCM for the engine, plus virtually every other HS Bus module.
The cruise control is PCM controlled by stalk and brake/clutch switch inputs driving an electronic throttle body.
Gary
