Old 04-18-2011, 03:44 PM
RestoCreations's Avatar
RestoCreations RestoCreations is offline
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Default Could use a little help dialing in the bellhousing
So i have everything set up and i just took my measurements.
Measurements were taken rotating counterclockwise if facing the bellhousing.
I set the dial indicator to 0 at the 12 o clock mark, then rotated-90 degrees counterclockwise 3 times
Readings
90 degrees= -.008
180 degrees= -.018
270 degrees= -.009
Obviously i need to go up a good bit, but what about left to right? Since they are both negative and almost the same, what do i do? Excuse me for being a bit slow concerning this matter. I find it very confusing.
