Old 04-18-2011, 03:45 PM
Doubledip's Avatar
Doubledip Doubledip is offline
Send a message via ICQ to Doubledip
Originally Posted by DaveW View Post
How can i tell the type of controller i have, it has bar codes and part numbers "12597121" & "12603892" but nothing the resembles "E38" what ever that means.
What Controller should i have got for ease of operation ?
RE: Cruise control, if factory isn't the go, what is,
Where does it pick up the speed signal from, ABS Sensors ? Speedo ?, something else?, do i need a separate controller or is it part of Engine controller.
so ECU's have E38 on the white stickers .. others dont... but on the finned side if you look closely at the top you will see a tiny casting saying E38 (or E40 , E67)
as for the service part no.s 12597121 is a E38 (MY07 - originally VE) 12603892 is a E38 (MY06 - originally VZ)
as for curise i would recommend just sticking with factory setup... GM dont spend millions on this stuff to do it wrong. It can be setup and works excellent in a no Holden vehicle.. Speak to the workshop that is going to supply the harness for you and they should be able to set it up for you along with the ABS
www.ultimateconversionwiring.com.au
_
