Old 04-19-2011, 06:46 AM
mreid's Avatar
mreid mreid is offline
Cobra Make, Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
Your cam specifics and quality of rotating components determines redline. If it is unknown, I would limit your FE to 5800 until you know what you have for sure. While I agree that oil leaks are common, you don't have to live with them and they can eventually cause bigger problems like oil saturated clutch disks. Often, a rear main will seal itself with use, but many times leaky valve covers look like a rear main when the oil runs down the back of the block. Identify precisely what the problem is and then determine if or how you will fix it.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
