Originally Posted by Blas
Probably replacing all the silver material with something black would visually helpful. Especially the aluminum "dryer vent" across the back firewall. Perhaps a sheet of carbon fiber or just a dress-up aluminum plate on the side, Consider the header heat when picking materials.
One other thing, check the mounting of your coil. I believe that type should not be mounted in the horizontal position.
I agree 100% with your comments. That was what I was thinking. I just wanted to see if someone might have an idea that I did not think of. I like the carbon fiber idea. Any ideas on a different type of black tubing? It has 6" with insulation and then 4" tubing inside that.
Jake
