Thread: First drive
  #26 (permalink)
Old 04-20-2011, 05:21 AM
Doubledip's Avatar
Doubledip Doubledip is offline
Send a message via ICQ to Doubledip
if you can grab a scanner and scan for codes before sending up Sambo that will be good.. seems you are running it around abit .. just dont take battery off as it will erase them before you get the scanner on to it...
then send them up with ecu and when i fix your reverse lockout i can turn them off as well.
Peter as for yours if you want run it around a little longer then you are welcome to send your ecu back up and i can turn them off as well if you like...
www.ultimateconversionwiring.com.au
_
