Old 04-20-2011, 11:34 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Have the housing narrowed and axles resplined--the versi axles are some of the beefiest axles out there and can be resplined
also this will give you an opt to center the pinion in case its not in the center of the rear---many of the cars back then had drivelines off set to right and this will cause an driveline alignment issue
