Old 04-21-2011, 03:38 PM
fordracing65's Avatar
fordracing65 fordracing65 is offline
Just ordered my parts would love to get advice from blykins and other engine builders on this sight, Dart sportsman block, Scat 4340 forged crank, Scat 4340 forged H beam rods, JE superlight pistons, hand fitted Plasma moly/iron ductile rings, Clevite H series main and rod bearings, hydraulic roller cam with lightweight transfer bar roller lifters, a double roller timing assembly, chrome moly push rods, Fel Pro regular gaskets, MLS head gaskets, APR head bolts, CNC'd AFR 227 heads, ported matched Victor series intake manifold, T&D shaft rockers, polished aluminium valve covers with billet breathers, new timing chain cover, a polished SFI harmonic balancer, ARP harmonic balancer bolt, SFI flex plate, a fully balanced(within 1/4 gram) rotating assembly, Mass-flow EFI system with an msd pro billet distributor, spark plugs, 8 quart Milodon oil pan & pickup, stainless steel allen bolts, Edelbrock high flow water pump, Chrome 1 wire alternator, March billet alternator bracket, March billet serpentine pulleys, Chrome dip stick.
Should take me a few months to put together then dyno i will post results then, thanks for any advice.
PRIDEnJOY
