  #77 (permalink)
Old 04-22-2011, 02:55 PM
Doubledip's Avatar
Doubledip Doubledip is offline
Send a message via ICQ to Doubledip
Easier still...get new pins that go inside the plugs...shorten the wires , crimp on the new pins and put them back in to the plug. The pins are available at good auto elec supply and you can buy crimpers and pin removal tools from Jaycar for not much $.
Rob, none of those places would have what would be needed to shorten these harness with new pins etc.... only Jaycar would have the solder and heatshrink. The pins etc. are very specialised and 99.9% of autoelec's out there wouldnt have them.
I think the plugs/pins you are thinking/referring to are the Narva white plugs with the normal brass or silver crimp terminals as used in relay holders.. none of that is used in these harnesses. They are all the delphi style plugs which have very small terminal and most need a special crimping tool.. especially the ECU terminals as it is near on impossible to try and just fit the wire and terminals into the ECU plug with out them.
www.ultimateconversionwiring.com.au
_
