Old 04-22-2011, 05:07 PM
rodneym's Avatar
rodneym rodneym is offline
Full Blown Member
Premier Contributor
Default Mag wheel update
In answer to Rodknock's questions:
1. A new technique for coloring will be used. Described as looking accurate.
2. The 'COBRA II' embossing is still up in the air until next week when he speaks to his supplier.
3. He will use the same supplier as before. Nuff said.
If you haven't contacted Fran, do so. (412) 441-5750
He hasn't heard from A N Y O N E ! ! !
Learn your backspacing. If you have a CSX or KMP with Trigos, and you have no reason to believe they've been changed, then you can find your backspacing on the Trigo website. I don't want to just give the answer away because ultimately YOU are responsible for knowing your own backspacing. Double check it.
PM me so we can leave FORUM alone.
rodneym
