Old 04-23-2011, 02:58 PM
streetrod1927's Avatar
streetrod1927 streetrod1927 is offline
Cobra Make, Engine: Contemporary Classic Motor Car; 427 S/O
Drain water in Radiator until below water goose neck on intake manifold. Un-clamp top water hose from tank as well as overflow and return hoses if you have them. Unscrew 2 bolts connecting tank to intake manifold. You may have to lightly cut around the connection between the tank and the intake to loosen the gasket. Be sure clean all mounting surfaces, replace gasket and put ant-seize on the bolts before putting it back together. Check for leaks.....
