Old 04-24-2011, 07:44 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Originally Posted by DAVID GAGNARD View Post
If you explain how to this dummy how to do this, I certainly will try it, but have no clue how to do it.......
I will need simple step by step instructions.....as I'm not that computer savvy.........
David
Your DSL router will have an IP address of its own. Something like 10.0.1.1 or 192.168.0.1. So in your browser type those addresses and see what happens. If it does, chances are you'll log in with a username of admin and no password. (I'm saying that because it sounds like noone set it up yet). From there you will get an administrator web page and somewhere in there will be statistics page. It should list your uplink (960(?) Kbit) and downlink (1.5-7mbit) speeds. If they aren't what you're paying for then reboot the router and try again. If it still isn't working call your DSL provider.
Note: The address of 10.0.1.1 or 192.168.0.1 might be different depending on your setup. If you have a "network" icon in your task bar just hover over it and it will give you the address assigned to your computer. If it is a.b.c.d, c will likely be 0, and d some random number. You want to go to a.b.c.1 as your first try.
Good luck.
P.S. You're in LA - is your provider Century Link? They just bought Qwest...
Tony
CSX4005LA
