Old 04-25-2011, 08:14 PM
mickmate's Avatar
mickmate mickmate is offline
The cowl tube shouldn't be flexing anywhere near that much. If it is bolted through at the firewall how can it? Does it have the small support tube under the body edge at the back of the cowl? The cockpit is molded into the CCX body and should not be moving unless something has broken or separated. Check the windsheild hardware and mounting method as previously suggested. Does it have a bracket in the centre attaching it to the cowl? You should have some welting between the body and chassis I believe.
mickmate
http://www.actoncustom.com/
