Old 04-26-2011, 08:10 PM
Pman1961 Pman1961 is offline
Cobra Make, Engine: Superformance SP02423 KCR 445W 611hp 599ft lbs
Default Will my fuel line size be sufficient?
I have a Superformance with the factory steel tube fuel line. Appears to be 3/8" o.d. Will the factory line be sufficient for a 555hp 408 windsor or while the motor is out would it be a good time to increase the size? If so...what size do you recommend and would you rerun steel line or use steel braided all the way? Also, routing. Same as factory Superformance or I'm up for suggestions and photos if possible? Thanks
