Thread: fuel psi gage
Old 04-26-2011, 09:37 PM
OZCOBRA's Avatar
OZCOBRA OZCOBRA is offline
Exclamation
Originally Posted by ItBites View Post
I use mine for diagnostics while driving. If it burps in a corner, I can see the pressure drop for an instant and know I uncovered the pickup (and know to leave more gas in the tank). I can also tell the health of my pump (I've killed two). When the pressure doesnt jump right up at the key turn, I know the pump is on its way out... I have a vaccuum reference regulator, so I can also verify at a glance the regulator is responding to different vaccuum conditions. If my data logger starts telling me we are having lean conditions, I can monitor the pressure to verify the lean requires a map change vs the pump getting weak (keeps me from screwing up a perfectly good fuel map to cover for a pump growing weak). That sort of stuff.
littlewave,
In answer to your question below ,If you use it as above a great tool.
Originally Posted by littlewave View Post
OZCOBRA , I guess my question is, is a fuel psi gage impotant to monitor with an efi system?
....and yes great to check at a quick glance as fuel pressure is an important function with EFI .....
