Thread: fuel psi gage
Old 04-27-2011, 07:51 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Most fuel pressure regulators used on EFI systems have a port for a pressure gauge on them to set up the system. Once I got my system set up the only time I reference it is when I'm working on the system so it stays connected to the regulator under the hood. If you want to monitor fuel pressure while running follow the advice given about not running a wet gauge for fuel in the cockpit.
DonC
