Old 04-28-2011, 03:29 AM
Default I will be careful Jamo
D-cel Jason A iron block as it limits. Pushing over 800 HP is alot for motor block that get about 500 hp. I have not seen anywhere if this was a factory cast bvlock or after market one. I have not seen ALL the picture of the flywheel but looking at 2 new pictures see that a piece or pieces spun inside the housing to twist it off. Looks like they hit the starter hole or clutch arm hole. This will possible happen with ANY bell housing.
I like the QT bellhousing because of the weight different and the compact size. I also think that a tighter space of the clutch assembly help stop some of the damage pieces from blowing out of the bellhousing.
As far as I am concerned the bell did it's job. If this was in a car the driver would still that legs. This is the important thing. Rick L.
