  #32 (permalink)
Old 05-01-2011, 12:31 PM
RedSnake351's Avatar
RedSnake351 RedSnake351 is offline
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Originally Posted by slow_motion View Post
If that's the case, try and find out what caused this failure. Is you oil pump locked up? Might be time to remove the oil pan -- and at least find out if there's any metal from the sheer. Good luck
SloMo, good to see that you're still around, haven't heard from you in a long time!
AND you think Wolfie is about to pull his oil pan? You don't know Wolfie!!!
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
