Old 05-01-2011, 09:46 PM
Outwest34au's Avatar
Outwest34au Outwest34au is offline
Cobra Make, Engine: Evans kit, 6 litre, 6 speed, Jag F/R,
Originally Posted by renovationinnov View Post
i would check measure the chassic from centre to be sure that both sides are not positive /or neg while your at it
or worst case is the jig it was welded on had moved so then left is a heap neg
let use know what happened
ROB
Hi Rob,
the LHS will be marginal 3mm negative with no shims at all. Of course I will have to allow some shimming for caster though which may pull it back less than 3 mm. Time will tell on that one.
If I had bulk negative it would not really be an issue (apart from centreline geometry) as it could easily be shimmed toward positive bias.
I ended up with the Evans kit after he split from Paul at W & E. Obviously this guy was pumping a few out and didn't have the same respect for quality build as Paul did/ does. I have spoke with Paul a few times but since my kit was after the split I am the owner of a bast*rd child. Nothing that cant be fixed, just sloppy at the factory or backyard colourbond shed or wherever he built them.
Appreciate your thought time though.
Gary
Missed my Cobra budget by thaaaat much.
Ya get that on big jobs.
