Thread: Car Stalls
Old 05-03-2011, 11:56 AM
zzmac's Avatar
zzmac zzmac is offline
Cobra Make, Engine: Superformance, Roush 402R
Originally Posted by Blas View Post
Do you have viewports on your carb bowls?
If so check the float levels...if you don's see fuel on the viewports perhaps a few taps on the carb bowls will release the floats...Winter fuel is another common problem.
Good suggestion with the carb Blas, thanks I'll check that out. If all else fails at the end of the day would you suggest draining out half (or most) the fuel and replace with new stuff?
