Old 01-31-2002, 06:03 AM
Frank Coppola's Avatar
Frank Coppola Frank Coppola is offline
Clois,
Do you know if you're gauge is correct? I gave up on S&W mechanical gauges and went with another brand that was more accurate. Put the sensor in some boiling water and check the calibration.
My cobra ran hot, so I bought the dual aluminum fans from Enzo for pusher fans and a Mr. Gasket 16" fan as a puller. I went for a dual core Griffin aluminum radiator and the cool flex hose. If my car is not in motion the fans (all 3) have to be on. I installed a permacool thermostat/ relay which allows me to turn the fans on manually.
Haven't had a problem since.
I know it was mentioned before, but I too think you should check your timing.
Good Luck!
Frank Coppola
___________________________________
"Gunga Galunga... gunga, gunga-galunga."
