05-04-2011, 10:00 PM
QLD
Originally Posted by muzzza
Target will be to get pinion and gearbox axes as close as possible to parallel with no more than about 15mm offset tbetween axes to ensure needle rollers in uni joints get enough movement to lubricate properly.
Thanks..........Murray
Is the engine in the Harrison moved a little to the right or is it on the chassis center line?.
