Old 05-06-2011, 08:16 AM
bret a ewing bret a ewing is offline
Cobra Make, Engine: Look-a-like cobra POS
Pulled the wheel, the upper ball joint is fixed not slotted. So, the only option would be to adjust caster at the heim joint, only problem is front and rear adjustment nuts are bottomed (shortest possible a-arm length) against the heim joint. Do I cut off part of the rear arms to allow more caster adjustment?
BTW checked the printout for the last alignment and the caster was -0.3 on both left and right side, hence why I have to make a change.
B. Ewing
