Old 05-07-2011, 06:16 AM
Rick Parker's Avatar
I believe the technology was the same for many British cars too. The BMC Minis that I had in the past did not have Ballast resistor either, they used resistance wire. Find some examples of OEM wiring diagrams from the 60's in some "Chilton or Motors Manual books " at a library and you will see the (+) coil wire willl be noted as resistance wire. Cheapest way to achieve the desired results in an OEM appplication, especially in a damp environment (England). Fewer connectors to corode over time.
Rick
