Old 05-07-2011, 02:47 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
If you have a wiring schematic, find the common feed "+" that powers all those items you listed. Your ignition is most likely not powered by the same common source (probably its uninterupted power came directly from the alternator...That's why the car continued to run.
Your main ground at the battery is another thing to check, as is the main fuse...as mentioned earlier the cut-off switch
Not a good thing the power disconnecting and disconnecting - A power surge can damage electronic components. I don't have a Backdraft wiring schematic in my files, or I might be able to make a better guess...
SPFWiringDiagrams@Comcast.net
