Old 05-08-2011, 01:09 PM
Default Your total out of round is .010"
RestoCreations You out of center is .010" Side to side need a tap to move the bell toward 9 o'clock. Top to bottom is perfect. You have sent time trying to get this centered, a good tap with a hammer from your right to left should help get the numbers closer to "0". You want to end up with .000" top and bottom and -.002" on both sides at 3 and 9. This will be centered and you will have out of round .002" which is well with in spec. If the spec is .005" you are still out of spec IMO. Which off set pins did you get? They should have a large slot to rotate them. If you have the room to work adding allen head bolts to lock off the movement of the pins once they are in spec. You need to drill and tap a hole into the pin hole I know it's a pain in the butt but they will never move again. Rick L.
