Old 05-08-2011, 08:26 PM
AL427SBF AL427SBF is offline
All the gruesome details -
Work Performed
Honed bore of Innovators West Dampner
Intake port matched to heads
Measured bearing clearances, used standard bearings and X-Std bearings to get oil clearances perfect
Honed Big Ends of Rods
Dialed in Bell Housing
Pilot Bearing bored for TKO input shaft clearance
Engine Block Final Boring
Pistons Balanced
Checked Balance on Rods
Measured crankshaft journals, provided additional clearance work as needed
Parts List
Cylinder Block
Dart 31345235 Aluminum Block 9.500 Deck for 4.125 Bore 351C/351W
FP602S Deck Dowels For 351W Block Decks
Rotating Assembly
SuperLight Rotating Assembly 351C Mains 351W Rods 4.000" Stroke
6.250" Rods. Custom Pistons HN Rod Brgs and H Main Brgs
Additional Mallory for internal Balance HM1.00 x 1.000
Additional Mallory for internal Balance HM .875" x 1.000
99999-HM Installed Mallory Labor
Heads and Intake manifold
Edelbrock Victor JR Heads 70CC 77389
Edelbrock 2981 Victor JR 1x4 Manifold
Options/Requirements
Performance Rod Bearings clevite CB-663 HN std. with Rotating Assy
Performance Main Bearings MS 1010 H std. W/Rotating Assy
DuraBond Performance Cam Bearing set for Dart Block
260-1028 Base Felpro Gasket Rebuild Set
Felpro 1262 Intake gasket, 95110SG Victor
1022 & 1023 Felpro Head Gaskets (Aluminum EDE Victor Heads)
Felpro 2921 Rear Seal Kit Performance
Felpro 2331 Race Set remainder
Felpro OS34508R Pan Set
Victor 95177SG Exhaust Gasket Set
ARP Oil Pump Drive Shaft 154-7901
Innovator west Aluminum SFI Dampner 4 bolt ser # 32831 # 204
690-028 Brass Pilot Bushing 289 Bored ID to .668"
Melling Hi-Vol Oil Pump performance pump 10833
March 1610 Pulley Set Aluminum Performance
Custom RaceTek Pistons 70CC Dish (cr 10.3:1)
Roller Rocker Systems
Comp Cams 1332-16 pro magnum roller rockers
Cylinder Head Valve Train Components
Ferrea F6202 1.600 x 5.060 11/32 Exhaust Valves
Ferrea F6207 2.055 x 5.060 11/32 Intake Valves
Camshaft & Lifter
Comp 35-426-8 Camshaft
Comp Cams 8931-16 Pro magnum roller lifters
Comp 928-16 Valve Springs
614-16 +.050 & 611-16 Std Valve Keepers
Comp 4700 Spring Cup set
Comp 741-16 Steel retainers
4776-16 Comp Spring Seat Shims
38-532-55 Valve Stem Seal Positive
camshaft thrust plate
CCA796016 Push Rods 7.650 5/16 Hi-Tech
ProGear Timing Set PG-4138
Transmission/Bell Housing/Clutch
11" Clutch - 5/16" Bolts - TKO 600 Setup
360850 McLeod 11 Pressure Plate Clutch
260871R McLeod 11" Performance reverse Disc
16031 Throw out Brg McLeod
McLeod Flywheel Lt. Wt 463200 Neutral Balance 28-33# Steel SFI
TCET4617 TKO 600 .82 5th Road Race Transmission
ANR 2253 Trans Mount
Lakewood Bell Hsg 15202
Lakewood Alignment Dowel set .014" offset
Miscellaneous
7200-180 MCS Hi-Performance 180 Degree Thermostat
Hi Torque 351WStarter (Gear Reduction) CVR 5055 ProTorque
Alternator Bracket
Pioneer Aluminum Timing Cover 500302s
Spark Plugs 14MM 3/4" Reach flat gasket style
8585 brass dist gear for his 8352 Distributor
Water Pump Edelbrock 8843
Fuel Log & Fittings, Carb Willey's
Ignition Components
MSD 8578 Distributor for Dart Block and Victor Intake Clearances
MSD 8222 Blaster Coil Epoxy Filled
MSD 6420 6AL Ignition Box
MSD 8010 Dist Hold Down Bracket
FMS M012259-M302 Black Wire Set
Gessford Custom Wire Loom Setup - Side Mount
Fasteners For Engine Assembly
ARP Block Head Studs for DART as follows:
AR36201LB Stud 1/2 x 3.62 90# W/ARP Lube
AR54L Stud 1/2" x 5.4 LG
2008514 Washer 1/2x7/8x.120" no chamfer
3008304 Nut 1/2-20 12PT
ARP Head Stud Kit 154-4203 1/2" SBF
ARP 554-9503 Accessory Bolt Kit
ARP 612-2000 (2) 612-3500 (2) for Water Pump
ARP 612-2000 5/16-18 2.5
ARP 612-3500 5/16-18 3.5
ARP Dampner Bolt
ARP 454-2101 Intake Bolt set
ARP 334-7203 R/A Studs 7/16-2.12 chg to 1.90" 200-7201
255-1002 ARP cam bolt
100-2801 ARP flywheel bolts
200-8558 ARP Washer set
150-2201 ARP Pressure Plate Bolt Set
MRG 6087 Oil Pan Bolt Set
MRG 1516 Fuel Pump Block Off Plate
Aviaid Oil Pan 351W 55356
Aviaid Oil Dip Stick Setup Dart Block
Harrison Tank, mounts & straps
