Old 01-31-2002, 01:21 PM
Wayne Maybury's Avatar
Wayne Maybury Wayne Maybury is offline
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
Default What temp is too hot?
Just wondering what temperature you guys feel is too hot. My 351W ran at about 190 in traffic last summer. I always had one eye on the temp but it never seemed to go higher than that. I tried a 180 thermostat as well as no thermostat but the temp stayed more or less in the same area. I was running a 50/50 blend of antifreeze and I have a CSI electric water pump as well as a 16" puller fan.
I plan on running a 90/10 water/antifreeze blend this year with water wetter and I am considering putting a switch in the fan circuit to be able to shut the fan off when on the highway since the engine appeared to run a bit hotter at 60 MPH if the fan was running than if it was off. I am not sure what the capacity of the fan is but it sure appears to move a lot of air. Anybody notice if their engine runs a bit hotter with the fan running on the highway?
Wayne
Don't get caught dead, sitting on your seat belt.
