Thread: Weigh in
  #22 (permalink)
Old 05-09-2011, 07:09 PM
Krait's Avatar
Krait Krait is offline
Originally Posted by OZCOBRA View Post
Krait what do you put the LR/RR issue down too??...21kgs seems a lot without you in!!
Fuel system,Battery..Cockpit????
Over the last week of so there's been a bit of work done to the front end to increase caster. Once that was done the car was corner weighted again and the spring perches adjusted. Had about half a tank of fuel this time. Battery location has always been behind the radiator.
Result was LF 270 RF 301
LR 311.5 RR 345.5
LR/RF Cross 612.5
RR/LF Cross 615.5
Total 1231kg inc 91kg driver ballast
3kg is a much better result.
Steers a lot better now too.
Also used the opportunity to install the Corvette sump that I've had sitting in my Saudi apartment for over a year. The original sump had scrape marks where it occasionally hits the edge of my driveway.
Geoff
