Old 05-10-2011, 01:17 PM
Keithc8 Keithc8 is offline
Default 460ci.FE Engine Special $11,995.00
Fully Machined 428 block
Stock 428 crankshaft offset ground 4.200 stroke
Scat 6700 I-beam rods
Diamond Custom pistons 10.1 compression
Clevite & Fed-Mog bearings
Pioneer SFI Damper
Comp Cams Custom Grind Camshaft
Morel Hyd.Roller lifters
Ford Racing timing set
Stock front cover & pointer
Melling High Volume oil pump
ARP oil pump drive
Moroso T-Style oil pan pick up & dip stick
Edelbrock Aluminum CNC Stage II heads set up complete
T&D Shaft mounted Race series rockers
Comp cams push rods
ARP Head bolts
Original police interceptor PI intake port matched
Edelbrock Aluminum water pump
MSD Dist. & KCR plug wires
KCR Logo finned valve covers
Fel-Pro Gaskets
Quick Fuel 780 carb
Bal.Blueprinted & Assm.Dyno tested & tuned
Please call with any questions 870-246-7460
Keith C
