So the inspection came back as a 97.75 out of 100. Not to bad... Here is the summary on the negatives:
NO DAMAGE. NO TOP, NO WINDOWS, NO HEATER, NO RADIO. ENGINE BACKFIRES ON DECEL AND BETWEEN SHIFTS, VERY NOTICEABLE THRU SIDE PIPES. MAY BE A TIMING ISSUE, ENGINE HAS CARB INSTEAD OF FUEL INJECTION, MAY BE RUNNING RICHER THAN NORMAL. MOTOR SEEMS TO BE QUIET, NO MISSING AT IDLE OR REVING UP ENGINE. NO INNER DOOR PANELS WITH FIBERGLASS DOORS. EASY TO BURN LEG ON SIDEPIPES DURING EXIT OF VEHICLE.
So what do you think the backfire issue would be from?
Here is the overall summary:
DEFINITE FAIR WEATHER VEHICLE ONLY. POWER STEERING AND BRAKES. THE CLUTCH IS NOT HIGH PERFORMANCE AND DEPRESSES NORMALLY. SEEMS TO BE A POWERFULL VEHICLE.
Reason: added summary
