Old 05-12-2011, 07:51 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Good, you did all the cheap stuff first...nothings worse then spending money and having the same problem...now we replace parts.
Refresh my memory...what alternator do you have?- A standard unit or a one wire?
It's looking more like a voltage regulator or alternator...
You probably know this but, if you have a one wire alternator, the voltage regulator is built in, the SPF unit should be disconnected...
Could be a funky battery too, Optima's have had some issues of late. You charged it overnight with it disconnected right?
Luckily, all these parts should be under warrantee for you, just some time to troubleshoot...
Blas
SPFWiringDiagrams@Comcast.net
